I went to a local trimmer yeasterday and he wanted £400 to £500 I thought I will do it for that my self but if I can find someone to do it for less than £200 I may rethink doing it my self
Wow that's a lot, I hope that was for the removal and re-fitting if it was you can remove it yourself, its not hard to do then drop off for them to re-trim, that might save you a few quid..... Guy I used is in Manchester if you are local.....
This is mine removed before it's re-trim
Then it back in re-trimmed, really happy with it, sunroof looks a different shade in the photo but its not in the flesh, just the crap phone photo....
Lots of guys have done themselves with no issues, the lining boards are not the issue its the original glue that decays, removing all the old stuff is the time consuming bit.
Anyone done this with a bt car? What did you do with the sun roof section?
Not sure there is a differance BT/ST?? Once the lining is out, you remove the sunroof which is really easy, you can then remove the sunroof blind and recover it along with the lining, the lining and blind both recovered in the photo.
The bt sun roof blind is a lot different to the st.
was worrying about the colour match as don't think you could trim the blind very easily on a bt car
