Graham Goode do replacement diaphragms and springs for the standard compressor housing dump valves as I had to replace mine a few years ago which caused cutting out at junctions etc. I had the same symptoms described above.
If this has been blanked off have you thought of trying something similar from a different model.
for example: https://www.google.co.uk/search?q=FM...QVfBs8QgjYImQI
may be a solution?
may be a solution?
