Originally posted by Dave
View Post
Rear wheel bearings
Originally posted by twin turbo View PostIf hubcarriers Are machined allitle wrong it can squese the bearings. Have heard before that its problem with bearings fail, and spin on hub so ruin that to..
I had the same issue with a set in the mondeo and had to remove them and the std ones sorted the problem.
Originally posted by Mark King View PostI had the same issue with a set in the mondeo and had to remove them and the std ones sorted the problem.
Originally posted by The Radman View Postwhat bearings are they fitting to them then? surely they would fit correct stuff?
Originally posted by c20tbo View Post
I cant make out a manufacturer name on there wheel bearing advert via site, I recon the hubs are slightly machined out of tolerance with the bearing being pressed in very tight once the stub has been put in its made it even tighter, I wonder if the anodising has caused issues
You get to the bottom of this yet rob?
Spoke with Greg about this today he said he's checked all the hubs he sent out and has them turned by John who is o c d with theses and the only time he has a a problem is with kit cars , and he sorted it , if you have a problem he said just send them back or he will refund you , there is a difference between the stanard ford ones he told me ?
Originally posted by xpackboy View PostSpoke with Greg about this today he said he's checked all the hubs he sent out and has them turned by John who is o c d with theses and the only time he has a a problem is with kit cars , and he sorted it , if you have a problem he said just send them back or he will refund you , there is a difference between the stanard ford ones he told me ?
