Car parts express & GGR extended shafts
  • Car parts express & GGR extended shafts
    I pulled a shaft on the fiesta today during mapping, luckily at very low speed so no damage but I need to buy extended shafts
    GGR does new extended complete ready to fit shafts for £390 a pair outright
    Car Parts Express do new extended complete ready to fit shafts for £320 outright
    Does anybody know the difference? Are car CPE ones refurbished joints maybe compared to GGR brand new?
    Marc
    Consider these aswell, bomb proof
    http://www.ebay.co.uk/itm/SIERRA-ESC...item20b9434c56
      they are all normal Sierra/scorpio 4x4 axels...
        When are longer shafts needed say for an Escos? or are they needed
          supposed to be when you have lowered the car Rob.
            Yeah, better engagement on lowered cars apparently
            Can't comment on CPE or GGR ones as don't have them but the Automotive ones have a beefed up joint so more reliable if you're running high power/torque....... i put my Automotive ones on shortly after getting the car so done about 40,000 miles on them with no issues atall. Warren Kelly had them on his Time Attack car too and had no issues as far as i'm aware
              Auto unlimited & ggr shafts look to ne made by one & the same company.
              John
                Who makes the GGR ones ?
                  AU came in shaftec boxes, GGR ones came loose. Could only tell them apart by the laser etched part number on the shaft.
                  John
                    Maybe the same then.....but only if GGR have uprated joint
                      Dave, yeah I presumed that but with my car running 18's and not sitting too low (coilovers) it surely cant be that much lower than running stock wheels and suspension, any one actually measured there chassis height from standard to say after market shocks and 18's are fitted
                      I can see why Marc needs them for his fez but if my car (escos) actually aint that much lower than stock with the longer shafts give it the reverse effect?
                      Rob
                        It's not the chassis height from the ground that matters. It's the distance between the hub and in inner cv that is changed by spring heights.
                        John
                          I'll prob get a set whilst my car is in bits, so which are best GGR or Autounlimited? do the GGR ones have uprated inner joint
                            I negotiated the purchse of my escos thinking that it needed a right side outer cv replacement.
                            It turned out the clearences in the diff were the real problem, allowing the inner cv to rotate on a random path as it sore fit.
                            As a result of the challenges of being on the other side of the world, a set of shafts arrived from auto unlimited before ggr. The a/u ones went in and the ggr ones are spares.
                            As I said before, they appear to be the same except for a number on the shaft. Ggr and autounlimited claim slightly different lengths over oem length.
                            Probably best to contact both and get the word direct.
                            John
