The discs are part of the brake kit so they came from hi spec. They are rotors with bells bolted on with a 310mm outside diameter. Personally I wouldn't bother with putting bigger calipers on the standard discs as you will not see much improvement and the discs will still only absorb the same amount of heat!
Do you know the thickness of area of disc that sits between the hub face and the wheel?.
