2wd fuel reg on 4x4 manifold
  • Tech Question - 2wd fuel reg on 4x4 manifold
    Hi guys will a 2wd fuel regulator fit straight on a 4x4 manifold?
    no. the 2wd is on a hose from fuelrail, 4x4 is fitted to the end. escos have another again. fuelrail 2wd vs 4x4 1 of the fastenign screws dont line up to manifold.
      ive just been told its a 2wd fuel rail on it, so is it just one of the fixing holes that wont line up?
        yes 1 bolt hole is in another position on the 4x4 vs 2wd plenium. 2wd fuelrail have a "hose" end both in and out, the 4x4 saph have a fuelreg bolted to the end With 2 screws, escos have a "internal" round fuelreg on top in the end.
          yes 1 bolt hole is in another position on the 4x4 vs 2wd plenium. 2wd fuelrail have a "hose" end both in and out, the 4x4 saph have a fuelrail bolted to the end With 2 screws, escos have a "internal" round fuelreg on top in the end.
          Thats a great help thank you mate!
            no problem, and ment fuelreg not fuelrail on 4x4saph
