any abs gurus or anyone worth sending car to
  • any abs gurus or anyone worth sending car to
    as title my escort abs light on and im unsure why looking to get it sorted before i put it into storage any help welcome thanks
    Did you try to drive the car after assembling the ABS system, as this could be necessary to force the ABS light to go off.
      no only short distances
        Are the pump working? How is the pedal? A common fail, is the pressure switch on abs unit, you got hard pedal and no brakes
          pump primes and stops pedal is perfect
            Are the light comming on just when you start or do you drive before it turns on?
              from the start
                Did it not sell then gus
                  no mate we was £500 apart
                    after having it apart have you plugged the drivers front sensor into the alarm switch plug by mistake its a common fault as they are thesame plugs in the same area check that 1st
                      Hope the abs doesn't cost you £500 to sort
                        I was thinking that
                          no id heavily discounted it from the asking price 2k off i wasnt prepared to go more than that off
                            ^^ that's understandable, there is doing a deal then a punter asking for the clothes off your back too
                              I had problems with mine. The plug of the dash dimmer caused it once (was un plugged )
                              2nd time was a fault with brake light switch. ( try starting with brake peddle pushed down to see if it goes off) I replaced brake light switch and it worked.
                              Just a couple of easy ones to try.
                              Ian
                              sigpicIan
