Part number needed..
  • Part number needed..
    Anyone know the part number for the gearbox mount needed to convert escos to RWD?
    L76 APJ Pacifica Blue 570bhp 460lbt SCS mapped
    Parts needed:
    2wd gearbox
    2wd prop (Shortened 47-55mm, but needs measuring)
    2wd sump
    Cometic 2wd sump gasket and half moon sealsModify oil pick up pipe (Bend slightly)
    Gearbox mount (Finis number 6177696)
    2wd starter motor
    Speedo cable
    2wd gearbox sandwich plate
    2wd clutch release bearing
    Dismantle front driveshafts and leave stubs in the hub
    Prop shortening places:
    http://www.propshaft.co.uk/contact.htm
    http://www.cylex-uk.co.uk/company/th...-16964961.html
      good advice there Stevie boy
        I like to have all info needed, so when there was a post on it I got all the info into one post and have used it 3 times since for other people Im working off that list for my Esc Cos, so will update it if needed
          cheers Fletch! yehh thats me just needing the gear box mount now got everything else lined up and will need to get my prop shortened will probably get oddkidd to do that once i have measured it, still unsure on what to do with my downpipe weather to live with the very close gap between tht and the box or change to a 2wd down pipe
            You reminded me I need to order the mount, bush and 2wd release bearing Is it the same bush as the Esc Cos mount? One thing I didn't add was who can shorten the prop
            How close does the 4x4 downpipe go near the box? Im running 4x4 exhaust manifold.
              Details added How much can Jano @ Oddkid do this for?
                Why do you need a 2wd sump?
                You can just leave the 4x4 one in place. Unless you want it to look right that is?
                  Does that mean leaving the front diff on also? Or is it completely sealed?
                  Does the 2wd bolt up to the 4x4 sump?
                    I know one car here in norway that has the front diff in place and t5 box so yes it should fit the 4x4 sump.
                    That said, you don't get engine oil in your diff do you?
                    Just take out the shaft that goes through the sump imo.
                      Good idea mate
                        emm im sure oddkidd said he was 290 to shorten the prob as all he was using from the old prop was the spline giving you a 3" single piece prop painted ready to fit.... as for the gap between the downpipe and the exhaust it was Dom who told me the gap was close and he changed his downpipe to a 2wd but its not just a straight forward swap, drop him a pm hes been a great help with me
                          I'm gonna try the 4x4 downpipe to see if it fits and deal with it then. Dom said you will need to dent the 4x4 one slightly.
                            Around £280 jano makes a single piece prop for my shortend 2wd prop might be for sale soon as it wont mount up to my new diff when i finally get one
                            And yea you can leave the 4x4 sump on, remove the diff and crosshaft and just run it like that. i was going to do it that way but i was unsure if i the starter would fit with my big wing 4x4 sump so i bought a big winged and baffled 2wd sump cheap enough
                              If your prop is up for sale give me a shout please mate I wanna get a 2wd big winged sump, but want a decent one and haven't seen any for sale?
