Heat shield mounting
  • Heat shield mounting
    Can anyone help me with pics of the heat shield mountings please thank you
    Which one Gus
      theres a clip that holds the bottom left iirc, hex bolt type fitting, the heat shield slides onto that and one that goes onto the standard air box.
        Any pictures I've no idea how the heat shield fixes pics would be good
          there must be holes in the shield Gus.
          put it in position and see where they meet up.
            Just go n take some pictures you bloody scouser
              you probably wont be able to see the mounts if I do.
                Lower one on the picture is the lower turbo heatshield bracket, upper (the hex one) is the middle fixing.
                  Any of them fitted? Thanks
                    the brackets fit to the inner wing lol.
                      restoration section.
                        sending you some pics in whats app.
                          The car is a bit of a shitter but you get the idea
                            here is one of the mounts
                              Originally posted by Mark-C View Post
                              The car is a bit of a shitter but you get the idea l]
                              Took me a while to work out who's car that was
