Got to do some repairs this year,small hole in nearside footwell and nearside outer sill. What gauge plate would be best for floorpan or can you get a panel to replace whole area? and which sill is best to use to fit?
floorpan and outer sill repair..
Originally posted by john trott View PostGot to do some repairs this year,small hole in nearside footwell and nearside outer sill. What gauge plate would be best for floorpan or can you get a panel to replace whole area? and which sill is best to use to fit?
1mm is fine.
Try not to go overboard and use battleship plate steel, as this causes more problems later down the line. The metal has to flex at a similar rate to the surrounding metal or else it will slowly cause fatigue fractures ( Over time).The repair also needs to deform in an impact at a similar rate to the surrounding steel.
Remember its a sierra floor pan so you could get a section of floor from a scrappy, or maybe some one has thought ahead and has cut sections out of Sierras already and sells the floor edges???
Frank
Originally posted by sixaxles View Postis it actually a sierra floorpan though - do you not have to shorten the prop when doing a 2wd conversion???
Frank
