Battery going flat ( Now sorted)
  • Battery going flat ( Now sorted)
    Left the Escos off the battery maintainer for about 18 days, locked and alarm on and now not enough power to start the car. How long does your battery last in same conditions. Battery is only 18 months old.
    www.sunnysidebb.co.uk
    Sounds typical.
    John
      Messure If something Are using power. Mine have been standing for months without problem, but some only stands few days...
        Possibly tracker draining it?
          As said above measure the drain on the battery see how many amps its pulling
            Check fur parasitic drain, easy to measure with a voltmeter when unplugging certain items of their power source.
              nah, it shouldn't do that.
              If it helps Frank i've only ever got 2 weeks on either of the cosworths that i've owned, the standard ford alarm and immobiliser draws current even when not activated.
                thanks Simon, that sounds about right then, It was just over 2 weeks. Bloody immobiliser has gone tits up. not the first time either so I'm in the process of ditching it. Will fit a more modern one.
                  mine had alarm/central locking that was draining the battery
                  Escort RS Cosworth
                  Impreza GC8 ver.6
                    Thanks everyone for you help/advice
                      I measured the current drain and was getting 400ma to start with then dropping to 240ma after 5 minutes . That's still about 2.5 W and 6 a/h per day . So over 2 weeks thats a lot of juice. ie 84 a/h and a flat battery. Now immobilisers been replaced with new the a/h is now 50ma. That's a bit more like it. Got rid of the the factory alarm also. Now fitted with the one device that does all 3.
