I purchased these fitting bars from XYZ fabrications I think it was, and had to play around with configurations of mounting and made it all fit in the end. Mine is an Airtec ic with an unknown alloy rad and fans.
Pro alloy Rad & Charge Cooler Install
I bolted it up that way to start with but yes couldn’t get the fan clearance. The bracket is the same thickness all the way along and basically the front part of the bracket is just not used so doesn’t really need to be there with my configuration. As it’s the same thickness all the way across I don’t see how it causes any excess strain with no extra weight that would be on the bracket if fitted up in the first picture. It’s has been fitted up for nearly two years now all good and solid still.
