I cannot get the pump to build up pressure therefore hard pedal and no rear brakes. I had it all apart to clean it up all back together 100% ( I think) no pressure tried a vaccum to help prime up. Big fat nothing Anyone know anything about this part ? or maybe point me in the right direction. Thanks folks.
Brake pressure pump
Do you still have the original ABS block? Air locks are notoriously hard to get rid of.sigpic
- 1 like
Originally posted by The Radman View Postare you getting fluid at the rears? mine was a pain and i had to get an eezibleed on it and pressurized it from a spare wheel to force it through
I have it on the floor at the moment just connected to a battery. Motor is going no problem it should pump out fluid to go to the master cylinder but nothing doing. I have it all apart now but cannot take apart the area where the impeller responsible for forcing it through.
Originally posted by Elfranco View PostTommi, check there is fluid coming through from the abs block, don’t no the name of it but the brake pipe that connects to it at the abs block could be blocked, seen that before
