Hello, after a few months in the garage (t35), it seems that I have some problem in the start up. Last time the car started well. I thought it was the battery, but have12.5V.
The starter makes noise, movement perhaps slow, but does not hook the flywheel. the battery cable in the starter has 12V in position III and turning the key 10V/9.5V. The ignition cable on the starter, has 0V in position III, and turning the key has 4V/5V. It seems that I can have the problem in the ignition cable? good battery volts, bad amps in the batery?
Many Thanks!
Many Thanks!
