Denso’s have a bad rep
Spark plugs
Not really used them on cossies but densos tend to crack on the ceramic on zetec turbos. Seen a few. But I wouldn’t let that put you off, even stock 071c’s which I use have their issues.sigpic
bringing back the subject again!
Just been getting the car ready for Marks final tune tweek..so. oil and filter change and replaced the standard cheep ( not even for a cosworth) champion plugs used for multiple start stop of engine whilst working on it. Replaced with IK27 ( see note) and within 2 to 3 minutes the idle went to shit and within 5 minutes it was missing at all revs. Car just wouldn't start after that. put the cheep plugs back in and runs fine. Put the 27's back in ( after engine had been running for a while and started and idled great on the champions) to find it still wouldn't start. Thats the second full pack of IK27 plugs that haven't even been driven on the road yet. I really need a plug that will run 500hp and not foul especially if the engine floods for what ever reason. it seems once IK27's get wet there fooked. What was the consensus for a non denso 500+ hp plug?
NOTE.To be fair at some point the temp sender plug had pulled off so the ik27 plugs must have been flooded so its didnt start at all when I fitted the 27's . I dried out the engine replaced the 27's again and it started but within 2 to 3 minutes it started to misfire and within 5 minutes turned into a sack of shit.. Then I put the champion plugs back in, it started instantly and no misfires.
Originally posted by garet View Post
Tried many plugs including the IK denso,simillar issue but....than tip fell off...after that motorcraft cheap ones and than all was good...btw,,,did anybody tried ngk iridium IX?
- 1 like
Originally posted by jsa View Post
The heat range is 6 is that a cold enough plug?
i belive the IK 27 are a much cooler plug.
Fitted these to mine recently - Motorcraft AGPR12PP
https://www.ebay.co.uk/itm/Ford-Sier...-127635-2958-0
