Grommet
  • Grommet
    Bulkhead grommets again. There is a smaller hole next to the big ecu wiring grommet. It’s around 55mm diameter. A big grommet does not fit it. As I found out being upside down for half an hour. Does anyone know any info as mine is missing?
    Cheers, Kev.
    Found a pic it’s quite a bit smaller than the other one.
    Cheers, Kev.
      Any pictures of what they should look like?
        Think it has the turbo gauge hose passing through it, or it could be the water feed hose to the tailgate.
          wow Kev, long time mate.
          hope your doing well.
          still got the car then.
            Hi Dave, yeah still got it. How’s tricks mate? Trying to get a bit of enthusiasm for it lol.
            My small grommet looked like a piece of black tape!! Some people were saying it’s the same as the other one but they don’t fit. The big one is about 63mm hole size, the small is around 55 ish.
            I want to put the vacuum hose, water injection pipe and the wires from the main car loom to the ecu.
            Cheers, Kev.
              have a chat with James at Autodynamix, he makes up all the new engine looms that include the large grommet, he might have or know someone who can supplier the smaller one.
                Would this work?
                50mm OD for shell fitment for hole
                ID is 12.5mm for where you want to run your cables pipes etc
                  That would be very close I think. What is it off??
                  Cheers, Kev.
                    im good thanks Kev, really busy with work so cannot complain.
                    same here, not used mine for a while.
