Originally posted by Grand Tomismo
View Post
Ride hight dilemma
So after speaking with graham Goode they are still saying they are the right springs -22mm -35mm they send to fit the front as well as I’ve only fitted the back however I can’t see how lowering the front will make the back lower, so they have send them back I’ve fitted the rear and yep still 675 on the rear am I missing something how can the rear not be getting lower, are there different top spring rubber mounts they are ford ones on it
rear mounts are all the same ,you can get poly ones but still same thickness so that wouldnt make a difference,ive had every spring going in the past and ggr ones dont seem to drop them much imo,ive always ended up with eibachs,nice and low but probably a bit too low sometimes giving a lot of camber,bet you wish youd probably left it on coil overs now
Originally posted by The Radman View Postrear mounts are all the same ,you can get poly ones but still same thickness so that wouldnt make a difference,ive had every spring going in the past and ggr ones dont seem to drop them much imo,ive always ended up with eibachs,nice and low but probably a bit too low sometimes giving a lot of camber,bet you wish youd probably left it on coil overs now
Originally posted by Dan Le Moignan View PostI don’t think so personally
Originally posted by Darrenaf View Post
Dan you bought my Bayhoo spring/Koni setup off me, did you fit them and get a drop, because when i fitted them to my car the ride height remained standard and i was expecting 25mm lower or so, i never run the car down the road with them on, driving the car may help it go down. OP, Might be worth driving it to see if it drops when you can.
