Know of 2 heads needing work, 1 is 137.5 the other is 138,5mm. Tjis is offcourse abit too much skimmed, but i realy wondering if its worth it or not... The 1 138.5 i dont fear that much on a low spec engine, but still not ideal. The other i guess new valvesears futher in would be the way forward if should trust it again?
Head thickness...
Probable best to put some pictures up I have a few that have been skimmed to that level and the top of the valve seats have had bits shaved off
I would of thought you be looking at minimum of £600 to get that sort of work carried out. Then when you go to that level you may want to get corrosion welded, new valve guides etc soon totals up
Originally posted by Joe-Tait View PostProbable best to put some pictures up I have a few that have been skimmed to that level and the top of the valve seats have had bits shaved off
