Expansion tank.
  • Expansion tank.
    Hi all.
    I might have to buy a new ally header tank. Mine see pics, has screw type fitting -6 ??? One from the swirl pot and one from the turbo rad.. A new ally tank will come with standard hose fitments using hose clampsHow can I mate the fittings I have(picture) to the standard hose fitments?
    www.sunnysidebb.co.uk
    Is that pro alloy ? I got ggr
      Yes, I belive it is.
        if you cant find an off the shelf tank with the correct bosses then cut the stubs off new tank and weld some -6 bosses to it,"think automotive" and places like that sell the bosses
          Maybe something like this...
          https://www.summitracing.com/parts/e...6erl?rrec=true
            Thats an option. Thanks. I will trawl ebay and see whats going.
            Frank.
              Originally posted by VADreamer View Post
              Cheers. Its a male end I need but I recon they would have to be welded into the new tank .
              ive contacted Proalloy today and they recon they can supply a tank with a sight glass as well.
              Frank.
                That is a male -6 end. The other side has a ferule that compresses around straight tube/pipe.
                  Cheers. Would have used a smiley but the don't work
