Temp sender
  • Temp sender
    Does any one know the correct temperature sender for the dash temp gauge.
    I replaced the original as the connector broke off. Ever since fitting one off fleebay my gauge is just inside the rectangle under the red zone . Not quite out of the norm box. The temp reading on emtron is 89 deg rising to 92 and back when fans eventually kick in.
    My last escos sat some where between R and M .
    I know its not too hot but it keeps giving me the shits every time I look at it
    Thanks.
    www.sunnysidebb.co.uk
    Had the same issue..get the one from Burton or MSD...
      Thank god for that. Thought I was going to have to live with it near the Red. I know its not overheating but still my heart misses a few beats every time I look at the gauge.
      Thank you.
        Ye i know what you mean,,i was planning to fit some modern dash but decided to leave the oe one but the sender was showing also high range ...Right now Burton one is fitted and it works fine but tested MSD one and it is also in good range.
          Im going to get on it asap .Thank yor.
            Ive just ordered one from Burtons .
            Thanks all.
            Frank.
