300mm rear brake kit group buy
  • 300mm rear brake kit group buy
    Evening lads,
    Following on from the previous post regarding rear brakes would anyone be interested in a group buy?
    Dave/ XYZ fabrications would be doing them so you know quality will be spot on.
    Idea behind it is to try and sort a kit at a more favourable price vs what’s available at the moment.
    Kit would be based on good quality Wilwood 298mm x 20mm vented rotors to use your standard 4x4 calipers.
    Disk bells to suit above rotors and caliper mounting brackets and bolts.
    Splash gaurds to suit 300mm rotors
    Would need to check with Dave but sure various anodising colours and rotor variations (ie grooved/ J hook etc) could be done.
    Only item that would need sourcing would be the extended brake flex lines which I think Reyland do.
    Will start a list, then can get some idea of cost.
    1/ Dan Le Moignan- deposit paid
    2/ John- deposit paid
    3/ Dan_boy
    4/ AAran Trew- deposit paid
    5/ Nick Malone- deposit paid
    6/ Luke Darlington- deposit paid
    If these fit under the standard 16 inch wheels then, yes I’m interested.
      Yes John they do
        Great then I’m in. please put my name down.
          You can put my name down for a kit.
          Been threatening to pull the trigger on the Reyland kit for a while now but this sounds good.
            Will do Dan
              You can put my name down as well
                Will do
                  Guys for info these kits will be £360ish for the kit, let me know how would like in at that price
                    Would the disks be the narrow type, where the brake pad just fits, or are they wider where the pad only works on part of the disk? I assume the price does not include postage?
                      Hi John, sorry late reply as had no net access
                      Not 100% sure but would look to get around it by using a larger bell
                        Hey mate can you put me down on the list , only thing is I’d need a price shipped out of the uk as I’m out in aus , been looking at the Reyland kit so if this works out cheaper , great , also need a set up for the front
                          Just wondering is this group buy still happening? I'm still interested.
                            Evening, yes planning for it to but been side tracked at the moment as been away and then a few small issues with our house build.
                            Will try and crack on and message everyone on the list this wk to confirm numbers
                              PM sent to all to confirm numbers
