Practiced launching yesterday and 1st proper go the rear prop uj shat itself big style so looks like mine won't be there tommorrow
Need a shortened 2wd prop asap for central day
If you had a little more time i would of been able to sort one out but have too much to do as it is before the show.
What car is it for an why shorter, i would only use a single piece one for decent power and deffo if your gonna be sideways everywhere. Same as what i have on both my Rwd Escorts with 500+ in the mk4 and 400in the mk3. Neither of them have ever caused any issues. They are 3in with uprated nuckle between the prop and flange so nice bit of kit.
I think I have one here
I will go and check now and get back to you
Im near Gatwick, and you will be welcome to use it
I have actually got 2 shortened props here if you fancy a drive out your more tham welcome to borrow them
Thanks jacko really apreciate it mate. After having a proper look at the car in daylight it turns out its not the uj it's the rear of the prop where the rubber dampning is that is at fault. The front outer piece turns but the smaller innner section doesn't. Now been fixed with another rear section fitted.
Jano it's for a 2wd escort cos. How much would 1 of those 1 piece props cost.
ABUSE IT TILL IT BREAKS!!!
WHEN IT BREAKS CRY !!!
TEAM SHAKE "N" BAKE!!!!
