what head gasket do you use
  • what head gasket do you use
    going to change the head gasket on the escos, as oil is leaking out of one corner, at the mo its got a group a, just heard a few drifferent storys about drifferent gaskets, been told small turbo gaskets are good(guniune) but cometic arnt so good as the block and head needs to be 100% flat, i dont want to skim the block so what gaskets will be good for me, bearing in mind im running 2bar boost and would like to run more at a later date.
    thanks in-advance, george
    wrc multilayer
      wrc multilayer.........fit and forget but you must make sure the block and head are perfectly flat
        mountune wrc 4 layer on mine
          If you want it to last, you have no choice but to long stud and fit the Mountune multi-layer gasket, or you will be forever changing a normal type one.
            6 long studs and mountune wrc gasket on mine.
              well this is the route i may take, but not yet as money is alittle tight as i would only get it in the neck if the missus found out that i need to spend aload more money on it,
              so is there two different gaskets? a mountune one and a wrc one? as this is the route im going to go down now,has anyone used these without skiming the block? and with out long studing the block i guess you are all using ARP stud and nut kit, as this is what im using at the mo, and is the ARP kit resuable?
              thanks george
                had a look on ebay and has anyone used this company before as there alot cheaper than woodfords
                http://cgi.ebay.co.uk/COSWORTH-MOUNT...item27b15bbdcb
                  Just found this if its any help?
                  http://www.part-box.com/escortsierra...r-p-18188.html
                    what about ST head gasket mike i heard they are good?
                      if i were you id get rid of the arp's other wise it will be the block your replacing next, seen soo many blocks cracked due to them, long studding and wrc gasket is the way we go on most engines now, id go for that
                        here you go
                        http://cgi.ebay.co.uk/COSWORTH-MOUNT...tem27b1a015e2o
                        bargain
                          thats intresting, how are they causing to crack the block?
                            George you got a chip for those greys yet lol.
                            Will bell you in the week about the tow bar for the van mate.
                            Low Slung Denim.
                              i think its to do with the amount of stress put on the thread and area around it that causes it to crack where proper long studs pull at the bottom of the block
