right then i am thinking of going for the mike rainbird kit but do i have to modify my rear dust covers for them as i have just had these all painted up for my underside resto and what else needs modifing if anything some pics would be good showing the kit fitted and showing the dust covers if modded thanks in advance adam
300mm rear disc conversion
Just doing mine. It looked like the caliper would miss the dust cover. But mine is the Reyland kit so don't know if they are different.
Will have to have another look if it ever stops raining!!!Paul Hales
Originally posted by adam ant View Postright then i am thinking of going for the mike rainbird kit but do i have to modify my rear dust covers for them as i have just had these all painted up for my underside resto and what else needs modifing if anything some pics would be good showing the kit fitted and showing the dust covers if modded thanks in advance adam
Have you a way around this. If not PM me and I will tell you one.
Frank
Originally posted by Sunnysidebb View PostWhat are you doing for a hand / Parking brake. If you are relying on just a hydraulic handbrake then you will fall foul of the MOT. The rules say there must be an independent, mechanically operated safety (aka hand brake) fitted.
Frank
Originally posted by Tore_TJ View Postafaik the kit uses the standard caliper.
Frank
Originally posted by Sunnysidebb View PostThats cool, wish those kits were out when I did mine ( years ago) as I fitted AP's and a handbrake fix.
Frank
[QUOTE=dunccoss;267288]been playing with my hand brake caliper today and got it on after some work on the brackets just needs a paint up and some better bolts and a nice spacer instead of the washers any way here are some pics to show you what i have done so far
[quote=georgie1;286529]look what dunc had to do
Originally posted by dunccossbeen playing with my hand brake caliper today and got it on after some work on the brackets just needs a paint up and some better bolts and a nice spacer instead of the washers any way here are some pics to show you what i have done so far
There is also a much much quicker way that keeps to the letter of the rules although its a joke really. Full Hydraulic Handbrake with a mechanical aid.I did it the later way on the Rally Car to get it to pass an MOT.
Frank
