as above i have fitted the drivers side hub and drive shaft flange i put plenty of grease on the spline before putting through the hub it moved quite freely before it was all the way in but now it hadrly turns i can turn it using a bar in between studs but it is so tight is this normal surely not,could it be that i have pushed the shaft too far through the hub any help would be helpfull here is a couple of pics with splash guard and brake disc paired up with caliper and one with out
fitting rear drive flang and hub
