DPE gearbox, What oil?
  • DPE gearbox, What oil?
    As title. What oil should i put in my DPE box? Its the one with straight cut 2nd and 3rd. Anyone any ideas?
    ask mike rainbird
      Fully synthetic 75/90 for the box and automatic transmission fluid in the transfer box I THINK it was Matt
        i used mobil 1 syncro oil, or something like that.
        got mine off Oilman.
          I would speak to the guy who builds them
            http://www.burtonpower.com/mobil1shc.html
              Ive always used Mobil SHC
                Any more input on this, I pick mine up on Saturday?
                  Why not just ask Pete it' his box but iv only used 75/90 With all his boxes of fitted
                    He told
                    me fully synthetic 75/90
                      I did and he said any 75/90 would do.
                      can either go ATF and protect the syncros or 75/90 and protect the gears, can't have both .
                      I had silkolene syn5 75/90 in it before and was difficult to select gears when cold butwas perfect when warmed through.
                      Im looking at Royal purple syncromax at the minute
                        I bought Titan race synchro
                          http://www.randbmotorsport.co.uk/sho...?ProductID=525
                          I've run this in mine for literally tens of thousands of miles.....then when I had a selector issue Pete stripped the box and the kit, despite the mileage, was like brand new!! As a result.......i wouldn't consider changing to anything else
                            Thanks for that
                            Pete said to use gear oil in the transfer casing as well. He can't understand why you need a thin oil that simply flings off a chain
                              Think its atf, since gearoil Are to thick, and dont lube the chain good enough
