Not in the normal offset to clear the outer wings - they will then rub on the repositioned beam. If you then use an offset to move the wheel out to clear this, then it needs the arch pulling.
Please note that you have to specify what beam you are running (or planning to run) when ordering, or you will end up requiring spacers if you order the wheels in an offset to suit the standard beam.
his wheels are designed to fot a car with shocks and springs not coil overs, so only mods needed are to inner wings and top suspension mount, but i dont know how much a beam will change it, as when these wheels are on a car you can still fit a hand under the arch between wheel and outer arch
Its f##king close to the trailing arm at the moment but as Rich says seems to be alright on outside arch.
