Turbo exhaust housing turning help/advice required
  • Turbo exhaust housing turning help/advice required
    Hi guys bought a GT30 turbo of Big jus yesturday and he was using a 2wd manifold im using a 4x4 one so i need to spin the housing round to allow it to fit my install. the inlet side was dead easy slackend bolts and its slipped round with ease..
    The exhaust side ive removed the bolts all but one (but its loose very loose) but i cant get the bleeder to shift at all..
    has anyone got any ideas what i can try ??
    advice would be very greatfull i had to leave it tonight as it peed me off...
    Let it soak with WD40 then try and tap it with a rubber hammer, due to the heat the exhaust side is always harder to free off.
      Yeah ive got it soaking now with wd40 on seems bloody tight like...
        when you undo the bolts on the housing, undo the nut so it pushes onto the body of the turbo so it pushes the ex housing outwards, use the turn of the bolt to ease it off if you know what i mean.
          yeah thats another option will try and jack it off sort of thing with the nuts securing it on.
            Careful not to push it one sided as it will catch the exhaust wheel
              yes, just a turn at a time each side, if you can turn it round too, that helps.
              it will come off.
                im frightend to do it in case i break the bloody thing ?
                  Have you try to heat it up?
