Hi all any tips on how to remove the steering with a air bag (smal turbo model) cheers Paul
Removing steering wheel with air bag
Two bolts behind the wheel for the air bag. I think from memory there 6mm then the air bag will come off disconnect horn push and air bag. Undo bolt for stg wheel then get and extension bar and hit the stg colum were the bolt goes in to shock and free it up. Turn the key a few clicks then the wheel comes off
Originally posted by Mark King View PostTwo bolts behind the wheel for the air bag. I think from memory there 6mm then the air bag will come off disconnect horn push and air bag. Undo bolt for stg wheel then get and extension bar and hit the stg colum were the bolt goes in to shock and free it up. Turn the key a few clicks then the wheel comes off
Cheers Fella
What is that fellaOriginally posted by grcossie View PostI you still using the oe instruments, then you have to mount a resistance in the airbag plug, to get warning light off
Will do fellaOriginally posted by cosmo View PostWhat is the rating of the resistor
Dont forget to disconnect the battery Paul
Were can i get from & is it straight plug inOriginally posted by cosmo View PostThat will be the 40-004 VLC
