Uprated engine mounts ???
  • Uprated engine mounts ???
    Do I actually need them ? Thinking of changing them for collins or vibra tec ones before i drop my engine in the escort , but are they really worth spending the £150-200?
    Car is 350-400hp and rwd.
    Low Slung Denim.
    it depends weather your prepared to risk your current mounts surviving, if they are your original ones, then there old and could be a future problem for you. The fast road vibras definitely transmitt more noise into the car, but otherwise no better than standard ones imo. Problem is standard ones are nla, even if you could source them your talking £140 each from ford.
    I think its more a case of aftermarket ones being the only option.
      imo yes.
      the old ones are years old and do come apart and you only know when the front shaft fooks up.
        Go for the Collins ones or be careful which vibratec you get as some are dry harsh so I have heard
          update them i went through two sets of gen ones ang some cv boots as well till i uprated them just fit and forget
          OH FUCK WHAT WAS THAT NOISE
            they are pretty strong too, when i had a smash in my car the alloy arm that holds the engine in snapped in two, the engine mount was ok.
              I got Collins ones Loader so i don't need to do them again,as your useing for track and drifting i would get them bud
                Ok sounds like the Collins ones will do me then
                Low Slung Denim.
                  my original ones gave up and as said wen underload put extra strain on driveshafts and these also fooked up, changed shafts and now ive got collins ones in mine loader and been fine for years mate.
                    Low Slung Denim.
