Has anybody got a list of the parts needed for a hydraulic clutch conversion (what size master and slave cylinder etc) as i dont fancy paying £350 when i can get the parts for about half that
Matt
slave cylinder is bmw e30 master cylinder is 0.625 girling you will need a female rose joint to match the master cylinder push rod & i have seen people use a m8socket cap bolt bolted through the clutch arm & then drilled out to take the slave cylinder
clutch arm measurements for rose joint
