What to look for with a suspected bent beam/arms.
  • What to look for with a suspected bent beam/arms.
    Does anyone have any experience with bent beams or trailing arms ? Is there any points to look at or measure to confirm a bent beam or arms ?
    Many thanks
    very difficult to tell, as the bodywork isn't always a good thing to measure off. you could try measuring of another suspension mounting point.
    where are you as i have a jig for the rear arms.
      What's your problem? Why do you suspect the beam/arms?
        Surely if it was bent, would it not be adjusted to the settings you want, therefore it won't matter if it's bent, well as long as its not bent a fair bit.
          Wrong details.
            I have no idea if this is the right link as I can't log onto PF at work but try here, I'm sure it has some suspension pick up measurements in here somewhere
            http://passionford.com/forum/ford-es...-geometry.html
              Camber and offset seems to completely wrong from one side to the other !!!
                Wrong details.
                Nutter lol
                  I have seen 2 escos whit bent bolting point to the main bush on beam. When i unscrew the bolts, they was bent also and the threads parts being bent over to one side
                    Have you had it on a proper 4 wheel floating laser alignment machine to get some figures?
                    Making a big assumption here, but I take it this is on a Cossie 4x4 YB converted Focus?
                      Wrong details.
                      Is is my first port of call mate , get some figures from a laser alignment machine , at least then I have something to work from .
