Engine block cleaning
  • Engine block cleaning
    Anyone know where would clean a engine block? Need it to remove surface rust.
    What's the best way to clean it? Acid dip or soda blasting etc?
    Where abouts are you? PM me if your in the North west
      I used a wire wheel on a grinder to do mine, took a long time but was mint after.
        Paint stripper, wire wheels and steal cleaner. Dry with air line, oil bores and paint with hammerite direct to rust, if you want it even glossier etch prime it and paint it with hammerite spray can
          I'm from the north east but willing to post any where.
            I've bought a standard bore 200 block, its not so much the outside i want cleaned, its quite dirty and rusty inside, all the main cap threads seem shitted up with crap so thought about dipping the block to get it cleaned up?
            Also the flame trap hole has a plate covering it can this be removed as its corroded.
              Looks like that plate is just riveted on
              Most companies that do cylinder head and engineering work should have the facilities to clean your block no problem
                http://img.tapatalk.com/d/12/11/29/je9ezude.jpg
                Jus get gordon scott to do it out of the durham club i will get hisnumber if you want
                  Yeah it is riveted on, was wondering if I can run the engine without it?
                  The turbo side of the block where you fit breather into doesn't have a plate reducing the amount of oil coming out so thought I could remove that plate aswell?
                    I think Jakki has his number, ill give him a call thanks
                      Sorry I read it wrong.
                      It's obviously there for a reason, I'd leave it personally
                        I wonder if I can get a new 1 fitted? I would hate for a piece come away in the future.
                          HI JUSTIN
                          that plate is there to stop it throwing oil out of the breather hole ,the oil hits it and runs back to sump ,you could remove and fit another quite easy
                          mark
                            Bead blasted, cover up all the ports though.
                            Before....
                            After....
                              When I done the block on my nova turbo I had it dipped in a hot de greaser and then I think it was a light acid solution bath then back in de greaser then water then dried, it came up awesome
