Top mounts
  • Top mounts
    Opinions on this please and can they be fitted with Koni's?
    http://www.ebay.co.uk/itm/Cosworth-9...item3a7e6f7eda
    Look good to me
      Wow, not cheap!!
      Scouse.
        I have them on mine. However I'm running 41mm Biltsteins and they require a special nut/spacer to fix them in properly. Konis have different tops and the seller mentions supplying sleeves to make them fit?
        Regardless, they really tighten up the front end!
          Do you have any picture of your spacer? I have some oe 909 ones, and have tryed to make them fittet to bilstein b6, the problem is they hit the standar spring cups
            Tried fitting them to my Black arts and they wouldn't fit. But I'm going to make some new sleeves so they fit. Look a well made bit of kit otherwise
              Are you using the oe ford bush or aftermarket ones - powerflex?
              thanks Karl
                Has nobody fitted them to standard shocks, or koni's then
                Got no response from the seller till yet
                  I have tried, but need modification to spring cup, to get the right height. Have not done that yet. Hopefully they will fit my bilstein`s when i got time to work on it
                    Has anyone fitted these with powerflex Top mount bushes, as i cant fathom mine, or am i missing the point somewhere??
                      No problem to use powerflex or standar top mount bushes
