Front drive shaft circlips inner ???
  • Tech Question - Front drive shaft circlips inner ???
    Hi guys I'm having a hells own job getting the near side front joint back onto the sump with the circlip fitted the drivers side flew in but I'm unsure if I should leave clips off I'm hearing different stories can anyone shed any light on it for me please as I'm on with it now.
    Cheers chaps
    Leave them on. Get a block of wood,put it at the end of the shaft,big hammer and knock it In. They can be tight but do go in.
    Thanks Mark.
    NORRISMOTORSPORT 01773836274
    WWW.NI-FORDS.CO.UK
      the only shaft that has a circlip on is the one that goes into the diff
      the shaft that goes into the to the other side doesnt have a clip hence your struggling to get it in
        I left mine off as you have to drain diff to remove it otherwise. The other shaft has a snap spring clip and will need a bit of a push for the shaft to go in lock with the ring. Same as taking it off, quick snatch and it usually, yep usually lol, comes out!
        Scouse.
          as said the very inner part of the shaft should have no circilp
          the sump side can but it means taking the diff plate off and there really is no need
          steve
          NSSCC 2016 Class B1 Champion
            Is he not talking about the clips in the recess of the shaft
            Thanks Mark.
            WWW.NI-FORDS.CO.UK
              Hi guys to clear this up I put a new inner cv joint on the N/s and is had a wire spring clip 5mm of the end of the spline but it wouldn't go in at all, I took it off bent it in a bit and got it in that way still tight as a nuns twot though, o/s shaft I hae just slotted that one in with nowt on to be fair...
                Rob you meant the one that protects the tripod joint?
                not the ones we were all rabbling on about lol
                steve
