im hoping someone on here has had the same problem and can help with this as im running out of ideas
what happens is on the overrun i get a rumbling type of noise,mainly noticeable in 3rd and 4th but only when the revs drop to around 3000rpm,the slightest bit of throttle and it stops again,it sounds exactly like when the down pipe is catching the bodyshell except it isnt,i run a standard exhaust so theres loads of room,at first i thought it was the rear diff so ive tried another and no difference,the weird thing is when its making the noise if you put the clutch in it stops it,let it out and it continues,applying the brakes makes no difference but if you put the h/brake on fully it stops it,let the h/brake off again and it starts again
all the mounts are fine/new,ive swapped exhausts,ive removed the h/brake cable completely,ive renewed the prop bearing and rubber insulator,the uj feel fine and tight,i know kev on here had the same thing and he also renewed the transfer chain and front diff and made no difference either,its got a new clutch/release bearing, the g/box seems spot on [its only done 25k] it drives spot on with no noises or anything at all apart from this one,any ideas?
rear cv joints are next on my list if i cant think of anything else
would welcome some advice also.
