300mm rear brake conversion
  • 300mm rear brake conversion
    Anybody used the st170 300mm front discs for a rear conversion on the Escos? I'm gonna have a play around next week, ordered some discs. Just wondered if anybody had already done it to save me making some templates for brackets
    Sound interesting! Keep us informed.
      How much do they cost ?
      PSN Ecossy93
        check out this thread on PF looking at doing this myself.
        http://passionford.com/forum/ford-es...-the-rear.html
        Some info on there.
          Yeah that's what I was looking at, once ive done it ill make a template and send it to anyone who wants it with some measurements for the spacers etc.
            Cool mate put me down for the dimensions and bracket info. i may get some for the track COSSY
            Info on disks.
            FORD Focus
            2.0L ST170
            2003 On
            Front
            Disc Brake Rotors
            DR2101
            Vented
            Diameter: 300
            Overall Height: 43.5
            Original Thickness: 24
            Minimum Thickness: 22
            Centre Hole: 63.5
            Stud Holes: 4
            They say 24mm thick did you have to do anything to the calipers to get them to fit? As i thought cosworth std rear disc,s are 20mm thick.
              Looking good if someone can get some brackets made up (Dave ?)
              PS just been to PF and it says I last visited two years ago
              PSN Ecossy93
                you need widen the carriers as they 24mm thick new discs ,14mm spacers and quite easy to make the brackets id measure mine but its 300miles away getting wiring done
                  I had a look at mine today and going by your pics, your brackets must be ever so thin to be able to fit in between the hub and the backing plate as shown in your pics on pf, they must be like 3mm plate and to me that seems way to thin because there is no way anything thicker would fit on mine.
                    6mm min thick plenty enough for the job I don't get what you mean there load of room I made mine with a backing plate on ?
                        Who can modify the rear calipers and possible refurbish them ?
                        PSN Ecossy93
                          I mean the tab part of the backing plate, in front of were the abs sensor mounts, the gap between that tab and the rear of the hub, there is defo no room on mine to fit a 6mm plate in between them, I'm gonna have to trim that tab off and sit the bracket just above the abs sensor.
                          This tab here
                          http://i777.photobucket.com/albums/y...laa/006-36.jpg
                            This tab here
                            strange one mine is 4x4 escort cosworth running gear just in a focus ,sensor still fits ,just don't run them now as running a modded abs loom ,only thing I had to do is trim a tad off the dust shield for the bolts on bracket the plate bolts infront of the dust shield
                              Yeah I can see yours fits between the shield and back of hub, mine is also a Escos so I can't understand how you have more space in between than i do? ill take a pic tomoz or Wednesday and show you what I mean, it's no biggy because I can just trim that shield tab off to allow my bracket to sit just on top of the abs sensor, I've already bored 4 pieces of ally bar as the 14mm spacers so as a soon as the discs arrive it should be plain sailing mate.
