thanks for all your replys, mike my car has a aero quip fuel line from the pump to the fuel filter, after the filter it goes back to standard lines, also my fuel return is standard as well.
can you please quote me for the swirl pot, fuel pump bracket and all connecting fuel lines to join it all up to my current fuel system.
i can get the 044 pump and do the wiring my self.
thanks
I'm on the case just costing up all the fittings to provide a DIY job for any Escort Cosworth .
mike if you can do a kit with everything we need, inc instructions and fixing, they will sell like hotcakes!! everyone will want one!! people dont understand all pipe fiting/sizes etc a kit would do the trick!!
well the kit would depend on your engine spec and what fuel lines you are running but if you want to run completely new fuel line from the tank to the engine and have filters/pumps/fuel pot in between then i can give you a complete list as i have just done this on mine using the proper teflon hose with clear outer so it dont smell of petrol in the garage
Any news on what the total cost would be pls Mike?
(thinking of trying to ensure I buy things that are future proof - plus I'm sure a few other peeps would be interested!!)
I just have to remember to measure the hose that goes from the fuel filter to the swirl pot, and then I can give a price for everything up to this point. Obviously it would be up to yourselves to sort out the fuel line from the pump(s) to the engine and to blank the return to the fuel tank (as this would then need to go to the swirl pot, so that the fuel tank was no longer being pressurised).
The swirl pots start at £200 for the one like Jays (but with single outlet). The hose from the fitting kit to the fuel filter is already on my website, and I would imagine the hose from the fuel filter to the swirl pot would be a similar price, but just want to measure it and check the fittings required to be sure.
