Exhaust joint sealant
  • Exhaust joint sealant
    Hi guys, do you need to put any exhaust joint sealant between the turbo and the exhaust front pipe, or does it seal without it when you tighten the flanges together?
    should be fine without trev
      I would just put a thin smear around it
        Now I don't know what to dooooo!
          didn't use any on mine, it was fine
            I'll do it that way then. Thanks guys.
              ive never used any on any of mine and they have been ok
                Nice one mate, it did look like you didn't need any but I just thought I'd check.
                  You shouldn't need any there really, once tight the shape of both parts should ensure a tight fit.
                    just make sure you get the front pipe away from the front prop shaft then you can tighten it up so it wont hit the front prop.
                      oh, ive never used any paste in all the years I have had cosworths.
