ST Air Bag Removal
  • ST Air Bag Removal
    Is it possible someone can advise me on how to remove the air bag from the steering wheel from St model please, as I have never tried to remove one before.
    Unhook your battery. Leave the car for a while, I think the manual says half an hour but I always leave it several hours just to be sure that the charge has drained from the capacitor.
    There are three bolts on the back of the steering wheel holding the airbag on. I think you might have to take the cowlings off to see them. Undo those and the airbag should pull forward, then you just have to unplug the wiring connectors.
      Thanks for that.
        Undo the two bolts make sure ign is off and unclip the yellow wire iv never had one go off with battrie on
          You're taking a chance there mate. I'd rather be safe than sorry.
          Actually it might be 2 bolts as David says, not 3, it's a while since I did one. But if it was me I'd unhook the battery and wait for a while.
            Iv done the same on bmw,s mate when i was in the body shop still no bags lol
              Blimey. I always thought you needed to leave them for a while to let the firing capacitor discharge, well I always do anyway.
                2 bolts as mentioned, battery disconnected and the air bag was safely removed. Thanks guys.
