Hydraulic clutch
  • Hydraulic clutch
    Just looking to order up all of the bits separate rather than buy a kit and I'm not sure what master cylinder to use.
    I was looking at either a 0.625 or a 0.7.
    Which would be the better choice?
    Also looking at getting something branded if it's worth doing, Wilwood with remote reservoir looks nice but I've read bad thing about them leaking
    AP are too pricey at £130 (could buy 4 ebay cheap ones for that and take my chances)
    Gilring are around £60 but the casting looks a bit rough
    Anyone give me there opinion please
    ask Mark Barber as he does the kits cheap.
      Yeah mate I seen those ones
      Only problem is I've already got the rose joint, lock not, spacers, reservoir, bracket.
      I only actually need the master and the slave cylinder
        iam curantly trying to get a wilwood drag slave to work... if it end up working, it should be a easier way then the others, since no modding on fork or bellhousing...
        it have enough movment, but I didnt get it to the bottom now, I need to change master to 0.75 or 0.813... have 0.7 now and dont get enough movment.
        img=http://i899.photobucket.com/albums/ac200/siggesen/sierra%20me%20bur/PC281124Medium_zps908f63b5.jpg
          Let me know how you get on mate
          Would be easier and more practical then a push rod type
            I messured today, on my 4x4 With to compare, and it should be enough as long as have enough movment on master and big enough
            it have a stroke of 35mm and oe moved around 30mm, so With correct master and fully movment it should be okay.
                there it came... needed to extend the rod, and grind allitle to get the washer to fit the fork better.
                  I'm not sure i'm getting enough movement with a Girling 0.625 so i've bought a 0.750 to see if it's any better
                  RS Cosworth Parts - MT-Motorsport
                    Ah I see, I'll have to have a look and see if I have clearance for it
                    I'll hang fire and see how you get on, I'm in no rush for it. I need the AP 6 paddle clutch kit as well, so I'm piecing this kit together for when the box comes out
