hoping someone can help me, the loom i have at some point had a 2wd engine loom and then an autronics loom, but i cannot find anywhere on the loom where these would of been joined
but i have these connectors i have no idea what there for and some wiring i dont understand why its been done
so any help would be great with the following
this wire is cut in half but its suppose to be together for some reason it splices into a black wire near battery cables and then goes to passenger inner wing main loom to two black/yellow cables, i have no idea why and it looks a mess and isnt std
next is my coil loom, this has a major extension to the point it can reach drivers side, the plug has been cut off and extended with two crimps and a std push on fitting, but the green wire has been cut near the original connector i think
next is fan loom
some ends have been taped up, and connector has a wire cut
these are on the passenger inner wing near bulkhead, what are they for?
and my reverse wiresi think, whats the power cable for? is this crank wire for starter?
these are all im stuck on at the mo any help
next is fan loom
