Long studding is it worth it? Discuss
  • Long studding is it worth it? Discuss
    Is it worth it on say a 400 engine ?
    have you asked one of the tuners who built engines
      There's lots of different opinions on it just wondering that's all before I decide for or against
        At 400 to 450 i say no not really
          Spec is going to be std Cr new Pistons machined for cams head just smoothed bd14 cams t34billet for now
            The fact you said for now, I'd say get long studs. .
              Lots of benafits to it and I cant see any real downside, If you have the budget it is worth every penny.
                Worth every penny for big build
                  get it long studded and decked so you can use a multi layer steel gasket.
                    Only regret with my engine build is I didn't long stud it. So limited to go any further into the 400 mark. But it's still a very fun spec and reliable.
                    You will most likely want to go for more power though, so long stud it and you won't have as many limitations. Everything else around the engine becomes weak
                      Yes I know that all too well after building a 720bhp Impreza and a 600hp Evo
                        Every time, don't scrimp on a relatively small cost to end up cracking your block
                          unless you are going high boost (+1,8bar), no need. stock bolts and group A/0611 will do the job
                          Escort RS Cosworth
                          Impreza GC8 ver.6
                            Iv seen 2 long studded block pull the treads out on the exhaust side lately had to drill and tap down 15mm deaper and get studs remade that much longer not seen a nikelsel block do it yet but may the studs are that much longer
                              What power was that producing though Dave?
