ESCOS now DIY set up
  • ESCOS now DIY set up
    ...using my rally cross boost control....how i set it up i actually get a peak
    1st gear 1.2bar
    2nd gear peak 1.6bar dropping to 1.3bar
    3rd gear peak 1.7bar dropping to 1.4bar
    4th gear peak 1.8bar dropping to 1.5bar
    5th gear peak 1.8bar dropping to 1.6bar
    With std transmission this is for reliability goes like sink on the NMS map (greys large T34 turbo etc etc)
    I reckon around 360bhp on the arse dyno Am allowed to peak at 2.5bar and hold 1.9bar in 5th gear but transmission says no
    Loving it how i set it up, took a fooking while though
    BOSCH PARTS 07759984033
    INJECTOR CLEANING
    Its a fucking good job i like myself isnt it.
    Any chance of a whip round for me to get me some friends around here!
    INJECTOR CLEANING
      I have to say Phil it means nothing to me, but sounds like your having a lot of fun in it
        P8?
          love u
            guessing you've got a wideband etc mate?
              Hows it programmed? Via the ECU?
                This is on L8 the boost controller is manual
                NMS map which i know is safe plus a afr gauge incar
                INJECTOR CLEANING
                  phil you are going to do a box lol!!
                    ....rainbird said it will be fine, but he also claimed he had 500bhp in a saff
                    INJECTOR CLEANING
                      Phil,
                      You're just making yourself look stupid, just because YOU don't understand DIN and SAE power figures .
                      Not my fault you're so stupid .
                        I only speak the truth...and you are a cock
                        INJECTOR CLEANING
                            He's got you there Mike!
                            Phil - Seriously, how does this boost controller work? As you say its programmed through the gears?
                              Franco its hard to explain but the controller can be set to run flat boost using a dual port actuator or a peak and held using a std one, the different boost in gear is just my way of using the controller.
                              INJECTOR CLEANING
