can you run a coilover with out the spring like normal ? carnt see why not but wanted to ask first
coilover question
Now that's an interesting question. Are we talking the rear ones, i.e. run with the coilover shock but with springs in the standard positions?
I'd be interested to know this because I know coilovers as standard are quite hard on the shell at the rear and various people have told me you should run a rear strutbrace to strengthen it and avoid cracking.
But if you run the standard springs so the force isn't all in the arch do you need to do that?Cheers
use my 25mm lowered springs on the back as befor and adjust the fronts to match, cozzylee good question that and that i dont know but i do know that when you buy coilovers you can have different spring rates and they dont change the shock do they
why not just buy a pair of rear Koni shocks to accompany the standard style lowered springs.
a pair of rears are hardly esxpensive and atleast then you can insure the springs and shocks are better matched to each other.
that way you could keep the rear coilovers as complete units, or even sell them on as a complete set of rear units!?
Coil-overs don't fit well in cossie rear turrets, you have to beat the arch to get clearence for the spring. The A frame spring negates the need for the extra width over the coilover.Originally posted by j1mbo View Postwhy bother in the first place dunc ?
whats wrong with your set up as it is
Originally posted by RWD_cossie_wil View PostCoil-overs don't fit well in cossie rear turrets, you have to beat the arch to get clearence for the spring. The A frame spring negates the need for the extra width over the coilover.
yeah i no they catch but thought dunc had them on his car already !
I just wanted to know thats all as at the moment i run a stage 2 rear beam and the B A D coilovers and wanted to know because of fitting large rear wheels as there is no way i will pull the rear arches on my car ( and its not for 10" mo's
