Originally posted by mikedaf2
View Post
18" New Escos wheels fitted Pictures thread
Links to template and General Info from Jan's signature
http://www.tigerworx.nl/images/cartboard.pdf
http://www.tigerworx.nl/folder.pdf
Originally posted by Clipper49 View Post
Maybe to you, but then i think cossys covered in chrome and other Halfords shite look gash. It's each to their own.
Right I have tried my big brake wheel and it fit as the sample one did with about 3mm of clearance I have ap 6pots CP5555 and 8 mm bells if that helps anyone
Hope this helps
I'm pretty sure on my brackets (Reyland iirc) it is possible to get the brackets the wrong way round.
The caliper will still fit but doesn't fit central over the disc so it sticks out further on one side, it might be worth checking.
Originally posted by cosman View PostRight I have tried my big brake wheel and it fit as the sample one did with about 3mm of clearance I have ap 6pots CP5555 and 8 mm bells if that helps anyone
Thing is dave there's so many brake suppliers and they're bell/bracket design differ so as 90 percent maybe fine as you say if the bell or brackets differ to most then it may put the caliper in the wrong position... I know of at least 5 different companies selling ap kits all machined by different people...
I have to say from an engineering point 3mm of clearance between caliper and wheel is not enough.
There will be tolerances built into the Hub, caliper brackets, drive flange, disc bell and the caliper itself, be on the wrong side of these and you will get contact.
With heat the caliper will expand and will contact the wheel.
