M12x1.5 60deegree cone, 27-28mm diameter. I got from a friend at Ford, for newer Ford wich is open, would just ask on Ford first, since allot of "pingpong" production out there wich can ruin the treads and stud...
these are the type you want with the spinning cones if you want orig look,i dont know why the sellers listed them as a diff pitch though as im sure fiestas are the same as escorts,maybe its a typo http://www.ebay.co.uk/itm/1224225099...%3AMEBIDX%3AIT
just check with him that diameter on cone is "big enough". Sure oe with " loose" sleve cone is prefered. But shouldnt be any problems with those either.
Nice one yes thats what i need the diameter to be big enough as the nuts off the TH wheel does not cover it fully when fitted. Them ones look like the right ones
The th should be same, if not "grpa" inserts, but those Are very difrent... But never know what been fitted by someone else before...
They are the wheel nuts that I bought with the Th wheels from Compomotive Mark Shead fitted and checked the fitment and recommended changing the nuts as the ones I have from the Th's don't have a washer.
