Plastic Side skirt rivets
  • Plastic Side skirt rivets
    Can these be bought from anywhere but Ford, I only want 1 and don't want to order another 10
    Mat
    how about ill send you one mat,when i receive the rubber stamp?
      Nick I will get it in the post this week, I keep forgetting
      Are you serious about sending a rivet out for me
      Mat
        yes,you should recieve it sometime in november
          Shut it
          I have just packed it up in an envelope and my wife is posting it tomorrow for you, now that's service
          When you are done can you send it on to Dave as he wanted it about a year ago too
          Mat
            will do,pm me your adress mat as i cant remember it
              Can you only get these from Ford? and also can you only get the full side skirt clip set from Ford? I've searched about a bit but cant see them anywhere else? I need the full set as i managed to break everything before it went to the bodyshop.
              I searched the forum and found plenty threads on the subject and how expensive they are from ford, bit did anyone find them elsewhere? Do any of you guys have a full set that is gathering dust on a shelf somewhere that you'd be prepeared to part with?
              Also does anyone know the finis number of the two plastic bits that are on the sides of the front bumper. Not the bumper bits but the bits that are attached to the body?
                the skirt clips are only available from ford,though someone did make some on here i think? dont know if he still has some?
                which bumper part do you mean,the big plastic wing nuts that you twist in?
                  posted this morning mat, thinking about it you could have just used a cable tie
                    A cable tie
                    Mat
                      Yep thats the ones, mine seem to have disappeared
                      Suppose it will be Ford for the other bits, got the finis numbers for them from another thread . If you know the finis for the twisty bits then let me know please.
                      cheeRS
                        David
                        Finis code is 6151261
                        taken from this thread in the Ford Database Collections sub forum, some really useful stuff in there if you have the time to browse
                        http://www.escortrscosworth.com/foru...read.php?t=144
                          Originally posted by Ben Purnell View Post
                          David
                          Many thanks
                          cheeRS
                            Originally posted by MATCOS View Post
                            A cable tie
                            you could have used a green one so it would blend in
