Escort st and my rev counter has stopped working. Does anybody have any ideas why or what to check? Which fuse etc had a look but can't see any issues??
help needed rev counter not working
If your BT , look down next to the coil and there is a small black unit half the size of a small match box with an electrical plug on it. Its the rev counter filter. You can pull off the plug and bridge across the 2 terminals in the plug to check if that is the issue. I dont run the filter any more. makes absolutely no difference in how the rev counter works.
Pin 11 on EDIS is tacho signal.
Use a multimeter set to Hz with engine running and backprobe pin 11 and ground.
Expect RPM/60=Hz
Could also measure same wire at tacho.
Use multimeter to see if you 12v power to tacho also.Cheers
John
- 1 like
