Side Skirt Fitting.
  • Side Skirt Fitting.
    When re-fitting the side skirts do you need to use tape/sealant or just use the fixing kit with nothing else, Any advise appreciated.
    fixing kit thats all and obviously the small bolt on the front section,fit the clips to the skirts,slide them side to side to get lined up with the holes in the sills then put a little bit of lube on the pointy end and push on to sill
      Cheers thanks for that.
